1910 solenoid replacement
   / 1910 solenoid replacement #11
Sorry. The post for the wire that goes into the starter is woobly. I think this is causing it not to make a complete connection to start. Plus the post is pretty much stripped.
   / 1910 solenoid replacement #12
most of the time that post can be replaced, even if it takes a bit of solder. could be a loost nut as well.
as for being stripped, that's what repair studs are for.
soundguy
   / 1910 solenoid replacement #13
That helps I am not afraid of solder. Where can I find repair studs from? Is that something that an auto parts store may have? The plastic that is at the top of the solenoid is starting to crack. I would assume that to solder I would have to break all that away.
Oreillys was able to find a similiar solenoid off of a mitsu deisel truck, but I brought it home and it didn't work. It seemed like it was a little bit too long.
   / 1910 solenoid replacement #14
to repair you'd likely have to disassemble it entirely.. i've done it before.. flipped contacts and all.. usually not worth it unless you can't find a new one.
now.. if it's all cracked up and falling apart.. that's another issue..
soundguy
2014 PETERBILT 386 DAY CAB (A54607)
2014 PETERBILT 386...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
