1910 solenoid replacement
   / 1910 solenoid replacement #11
Sorry. The post for the wire that goes into the starter is woobly. I think this is causing it not to make a complete connection to start. Plus the post is pretty much stripped.
   / 1910 solenoid replacement #12
most of the time that post can be replaced, even if it takes a bit of solder. could be a loost nut as well.
as for being stripped, that's what repair studs are for.
soundguy
   / 1910 solenoid replacement #13
That helps I am not afraid of solder. Where can I find repair studs from? Is that something that an auto parts store may have? The plastic that is at the top of the solenoid is starting to crack. I would assume that to solder I would have to break all that away.
Oreillys was able to find a similiar solenoid off of a mitsu deisel truck, but I brought it home and it didn't work. It seemed like it was a little bit too long.
   / 1910 solenoid replacement #14
to repair you'd likely have to disassemble it entirely.. i've done it before.. flipped contacts and all.. usually not worth it unless you can't find a new one.
now.. if it's all cracked up and falling apart.. that's another issue..
soundguy
7046 (A50322)
7046 (A50322)
2011 JOHN DEERE 323D SKID STEER (A53843)
2011 JOHN DEERE...
2014 MACK CHU DAY CAB (A53843)
2014 MACK CHU DAY...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
