1950 case tractor
   / 1950 case tractor #1
brian1950
Milwaukee, wi
1950 case tractor
Hi
I have a 1950 case VAI tractor. I used to own a 1931 ford model a, which required non detergent 30 weight oil. I have 6 quarts left over. Can I use this in my tractor?
Brian
   / 1950 case tractor #2
brian1950 said:
Hi
Brian
I would not. ND will just increase wear. Give it away or use it in a gear box calling for 30W or as bar oil for your chain saw.
Chris
   / 1950 case tractor #3
I use 30w non detergent in my Case Sc. Thats what the manual called for.
   / 1950 case tractor #4
we used to hang people and burn them for witchcraft back before we knew any better either.
there are plenty of better oils out there.
if a machine has an oil filter.. it will benefit from an oil with a detergent. this isn't 1927 :(
   / 1950 case tractor #5
Well the SC's like mine don't have a filter. They have a screen over the pick up in the oil pan and that's all. The holes in it are about 1/8inch in size.
   / 1950 case tractor #6
for that.. I'd say no detergent oil and not feel too bad about it.
That vai should be filtered though right?
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
