1953 jubilee
   / 1953 jubilee #11
naa hyds are their own beast.... have a manual ready and ask questions if you plan on getting into them...
   / 1953 jubilee
well he purchased the 53 jubilee no i got to help him with all the info on it such as how much oil it holds and what kind and what type hd oil and how much and trans as well i know the info is here i goggle it but didn't find what i was looking for help:confused:
   / 1953 jubilee #13
engine, buy 6 quarts, you will need some fo rhte oil bath air filter. I reccomend 15w40 if temps aren't below 0'F though 10w30 is usually fine int hem. red tiger OHV engines generally can make up to 55 psi oil pressure if not all calpped out.. even worn ones usually run in the mid 30's
you will want to use UTF fluid meeting M2C134spec for the hyds..
trans and diffy can use that utf, OR 80w90 gl5 gear oil.
hyds has a dipstick on left rear inspection cover.
tranny has a level plug aft of right heel just above the running board.
diffy have a level check plug on the left rear side of the axle trumpet.
I don't have my manual ready, but the hyds can hold UP TO 3g, but doesn't need more than 6-8 qts unless you are running external hyds.
diffy and trans will be similar.. 8qts or so.. economics wise.. just grabbing a 5g pail of utf fluid ( store brand fine if meets specs ).. will probably get you there.... might need an additional gallon for top offs.. but check first..
trans drain is under trans.. is a bung...fill is by shifter.
hyds drain is a bung under hyds center section.. fill is a cap under lft leg under seat.
diffy drain is a pip plug under diffy, fill is a cap under back of seat / right but cheek.
   / 1953 jubilee
sound guy thanks again i goggled it but it wanted me to down load a program and i didn't feel confrotable doing so this will really help i think he wants to change all the fluids so we will work on it some this weekend :thumbsup::thumbsup:
   / 1953 jubilee #15
always best to do a complete service on a new-to-you machine.
that includes greasing all lube points, front spindles, etc.
checking front wheel beairngs / hubs, front steering components, lubing steering box.. checking for play.. adjusting backlash on sector gears..and checking for thrust bearing play.. adjusting brakes.. checking for pto shaft thrust play / leaks..e tc.. etc.. do that befor ethe diffy and hyds service as removing the pto shaft to repalce a seal drains those 2 sumps. don't want to do it twice.. :)
   / 1953 jubilee
well my wife was right again and i hate when that happens. we been working on the 53 some not much don't have alot a time this time of year but she said when i got to working on it that wouldn't be long till i would want one i mentioned might look for one for winter progect and of course she said i new it. i see what happens.(to be contunied)
   / 1953 jubilee #17
yep.. they sense it...
   / 1953 jubilee
been checking out some 53 jubilees are all of them called golden jubilee or is that a serious of the 53 the one where working on now is a golden jubilee :confused:
   / 1953 jubilee #19
1953 was the 50'th aniversery for ford.. thus units built during that yer were dubbed the golden jubilee.. model is still a naa... SOME EARLY NAA WERE PRODUCED IN 1952 FOR THE MODEL YEAR 53 ( darn caps ).. then the 53 yr models.. then the 54 yr models that were only produced part of the year as the 5500 series started into production. thus what that means is the 1952 are the most scarce.. the 1954 are the next most scarce.. adn the 53 are the common ones :) few differences. nose badge and a bushing in the flywheel..e tc.. sn location..
   / 1953 jubilee
thanks again soundguy i wasn't aware that was the 50th aniversery we just noticed the id plate had golden jubilee now im intrested in seeing the actual manufacturing date when i go back to work on it i check it out.
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2013 RAM 4500 (A50323)
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2015 INTERNATIONAL DURASTAR 4400 WATER TRUCK (A53843)
2015 INTERNATIONAL...
