1953 Massey Ferguson problem.
   / 1953 Massey Ferguson problem. #11
Your TO 35 should handle a 6' box blade, a York rake, and a back blade just fine. It should also do well with a 6' finish mower.
I know it will run a 5' bush hog well, but I'm not sure about a 6' bush hog. The drive line will power it just fine. However, I don't know if the extra weight and the longer moment arm of the 6' over the 5' will lift the front wheels of a TO 35 off the ground. My MH 50 has a longer wheel base, so it has an advantage. I also have loaded rear tires with wheel weights. Even at that, if I let the clutch out too fast with the machine pointed up a hill, the front wheels will come off the ground, fortunately, only for a second. Perhaps someone with a TO 35 will chime in on this last point.
Most people don't realize how much larger a 6' bush hog is in comparison to a 5'. It just plays like a much larger piece of equipment.
CFG Industrial SAII100 (A50123)
CFG Industrial...
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2017 John Deere...
2025 Mower King SSRC (A50123)
2025 Mower King...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
