1955 Model 640 timing cover removal - help please
   / 1955 Model 640 timing cover removal - help please #11
In addition to the good info Sounder gave you, one other option would be to put the transmission in 4th gear to prevent the motor from turning.
   / 1955 Model 640 timing cover removal - help please #12
hey db, i love that sig line.. I've also seen it as 'turns money into smoke' :)
have a good one bud!
Yes - all good ideas although the impact wrench seemed to be the simplest solution based on what I'm working with. 4th gear was my first choice, but that did not work because I'm getting enough clutch slippage that the engine continued to turn even when in gear. It's a good tractor, but was ignored for many years and I've got a lot of catch-up work to do this winter. Thanks to all for the great advice! Bob
   / 1955 Model 640 timing cover removal - help please #14
impact wrench is a good one. it's what i would have grabbed first too. the other ways are just tricks or emergency steps when better steps aren't handy.. or when trying to test something.. etc..
   / 1955 Model 640 timing cover removal - help please #15
just a little tip use 1 or reverse have a helper apply the brakes put socket wrench on nut hit tool with hammer in the direction needed . but if you have impact us it nothing better.
   / 1955 Model 640 timing cover removal - help please #16
Another great idea - thanks! I ended up using the impact wrench and it worked like a champ. Tractor's up and running again and I couldn't be happier. Cheers, Bob
Skidloader Forks (A50774)
Skidloader Forks...
Electric Mobility Scooter (A51694)
Electric Mobility...
CFG Industrial MX20R (A50121)
CFG Industrial...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
