Buying Advice 1958 ford 800
/ 1958 ford 800 #1
ftw
camdenton mo
1958 ford 800
I met a man who had a ford 800 however it broke down on his farm and had been setting a few years. I asked him if he would sell it but I really couldn't quote him a price except as scrap. What would be a reasonable price?
/ 1958 ford 800 #2
500 - 5000.
There is not nearly enough information to answer your question.
What 800 model 840, 850, 860?
Does it have power steering, wheel weights, high lift?
How are the tires? 2 new rears will run close to 800.
Has it been sitting outside?
It is broke down? Does it need a new transmission, or a fuel filter?
Fill us in a little and I'm sure you get the information you are looking for.
/ 1958 ford 800 #3
Can you rebuild it yourself? Can you do some testing to see what needs fixing? If it is not running, it is a huge gamble to invest money into it if you can not do the work yourself and sometimes even if you can. Without knowing, you could be looking at a new engine, new transmission or other major problem. I just ended up rebuilding an 861D that I bought after I put less than one hour on the meter without warning, so they can lay down and die anytime, but if already dead; it is just a lot of metal bolted together. Buy it cheap because parts are expensive and experienced mechanics are even more rare and expensive.
/ 1958 ford 800 #4
:welcome:
To the forum from Northwest Alabama. I go to St. Louis often, go Cards, and I went to Cape Girardeau last week to pick up something I order at that new very big Menards there.
/ 1958 ford 800
What 800 model 840, 850, 860? I only know its a 800 model I didn't get close enough to tell which.
Does it have power steering, wheel weights, high lift? I don't think it had power steering and I don't remember any wheel weights.
How are the tires? 2 new rears will run close to 800. The tires aren't new and I think one or more are flat
Has it been sitting outside? Yes its has been sitting outside for quite a while.
It is broke down? Does it need a new transmission, or a fuel filter? It is broke down and the problem according to the owner something with the timing or a shear pin I'm not sure.
I don't want to put a lot of money in the purchase when it requires maintenance but I don't want to be unreasonable either.
