1958 Ford 841 temp rises pulling bush hog
   / 1958 Ford 841 temp rises pulling bush hog
Thanks for the info, is the thermostat in the top hose?
   / 1958 Ford 841 temp rises pulling bush hog #12
Yes. Remove the upper hose at the cylinder head water outlet elbow. Remove the bolts that hold the elbow and remove it to get to the tstat. Gas tractor full open at 180F, diesel open at 202F. They both start to open 20 degrees sooner.
Be sure the fan belt is tight. 1/4" deflection at the center of the belt. THe pump should put out 18 to 19 gpm. That's a lot.
TRUCKING INFO (A50775)
2023 PETERBILT 389 TANDEM AXLE SLEEPER (A53426)
2023 PETERBILT 389...
More info coming soon! (A50322)
More info coming...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2024 New Holland T8.410 MFWD Tractor (A53473)
2024 New Holland...
