1964 M/F 65 GAS WIRING DIAGRAM --------> DESPERATELY NEED
   / 1964 M/F 65 GAS WIRING DIAGRAM --------> DESPERATELY NEED #11
Yes :) I am at work at the moment, so I cannot double check, but there was something else he was looking for that did not appear on the diagram that I had found.. I don't remember what it is though. I was assuming that maybe there was another page to the diagram that I cannot find.
Here is a wiring diagram for a 135. The basics are the same for coil to distributor wiring. Basically the same for ignition switch, neutral safety switch. If you study the diagram it may help understand your existing wiring.
   / 1964 M/F 65 GAS WIRING DIAGRAM --------> DESPERATELY NEED #12
Hey Kid,
Whats the purpose of the inverter in there?
   / 1964 M/F 65 GAS WIRING DIAGRAM --------> DESPERATELY NEED #13
Hey Kid, Whats the purpose of the inverter in there?
The inverter was installed originally as a voltage regulator for the florescent type display that originally came on the 135's and could have on other Mf of same year. Input voltage was 12vdc and output was around 24-28v the gauges didn't use incandescent bulbs so. A special power supply was added to light up the specially lit gauges. These burned out of the years and many owners just didn't fix them of replaced them with conventional gauges with standard bulbs.
Is your tractor gas or diesel? Number of cylinders?
The best advice I can give you for the long haul is to acquire both operators manual and service manual. AGCO has a website to sell manuals to past and present production tractor and implements.
Goto: www.agcopubs.com. Usually the manually cover both gas and diesel engines. A wiring diagram is provided usually in the owners manual. The service manual covers very little about wiring. This site is all about sharing info and helping each other work out problems.
If your dads tractor has a specific problem we can indeed help. Providing pictures of wiring such as distributor plug wires injector pumps or whatever is a plus to keep the thread from turning into a guessing game.
You can also utilize AGCO's parts list website. Got: www.agcopartsbook.com and use the GUEST sign in and look up the 65. The parts list is broken down into areas of concern.
   / 1964 M/F 65 GAS WIRING DIAGRAM --------> DESPERATELY NEED #14
LOL!
Leave it to Coventry to go all the way around the barn to get to the front door.
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2014 Chevrolet Tahoe 4x4 SUV (A52377)
2014 Chevrolet...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
