Farmer495
Veteran Member
Doncaster built IH utility tractors are notorious for short clutch life, especially as hp and loader use increases. Clutch diameter is smaller than many competitors. Your experience is to be commended. That kind of clutch life is indicative of conscientious operation.
Hmm, that's on a 11" clutch too, 12" was option, but 12" standard on the bigger ones. What diameter do the MF and Ford of the same power and age use?
The ones I understood were hardest on clutches were the later FWA with the 8x8 shuttle, hyd clutch pack F/R but dry clutch, I knew one of those in a C60 that got ate in a 200-300 hundred hours from brand new, scraper/feed tractor on a dairy. Being able to easily use high range and 4x4 traction plus all loader work can kill a clutch.
