~1965 Case 530- Starter?
   / ~1965 Case 530- Starter? #1
Klitch
Benton City, WA
Case 530
I believe I've burned the solenoid up, but the starter was getting weak and I believe it'll cost me $200-$300 to rebuild the one on it, can I get something better/cheaper? It got to the point that I couldn't get it to crank fast enough with a good battery, being charged by a vehicle (14v) and 4ga jumper wire from post to starter post.
I think its a 1965 Case 530 with loader/hoe
I've found this guy on ebay but I haven't pulled mine out of the tractor yet
Starter Case Tractor 430 431 530 531 531C 570 580 580B 630 4 148 4 188 G176 G188 | eBay
   / ~1965 Case 530- Starter? #2
Klitch,
Just be careful to get the correct number of teeth on the starter bendix, especially if it's a 188 diesel engine. The older engines used a 9 tooth bendix. If no one has ever changed the flywheel ring gear and your starter has the 9 tooth, a 10 tooth (which is MUCH more popular) will NOT work.
Hope this helps,
Mark
Thanks for the advice, I was able to salvage the original starter, I will keep your advice in the back of my mind for when I need to replace the starter. Hopefully I don't have to. I see what you mean by the 10 tooth being more popular.
   / ~1965 Case 530- Starter? #4
I have a 64 Case 530 CK with the Gasoline engine. any advice on where to find a Replacement Starter or even a rebuild kit?
   / ~1965 Case 530- Starter? #5
I don't know that I've ever seen rebuild kits available. Check around and see if you have a local rebuild shop. Unless the armature is toast, it doesn't cost that much to have them rebuilt. We're very fortunate to have a great shop near by. He charges $35, plus parts needed. With bearings, new brushes, etc. it's normally around $60. Along with that, he cleans up the armature, blasts the case, and paints it, with a 1 year warranty. Turn around is normally 24 hrs.
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2026 Quality Steel 5x8 Trailer (A56859)
2026 Quality Steel...
1995 Rinker Captiva 190 (A55315)
1995 Rinker...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
RoGator RG1100C (A55315)
RoGator RG1100C...
