1967 hydraulic pump
/ 1967 hydraulic pump #1
jhp123
VA
1965 ford 5000 2000 new holland 1920 4wd, 1974 ford 5000, 1975 ford 9600, 1988 case Ih 885
I have a 1965 Ford 5000. The 3 point stopped working suddenly will not lift at all, even without a load. PTO still turns. Am I looking at a new hydraulic pump? Are there some more common smaller part failures that may cause this? If so, which one would you think is the most likely? We don't have a lot of experience diagnosing, don't want to just throw parts at it either hoping to find it. Too expensive and time consuming:)
HYDREMA 912HM ARTICULATED DUMP TRUCK (A65056)
HYDREMA 912HM...
2012 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2012 FORD F150...
JCT 72" Skid Steer Rotator (A64912)
JCT 72" Skid Steer...
2002 Harmon Steel Barrel 7,000 Gallon Asphalt T/A Tanker Trailer (A68183)
2002 Harmon Steel...
10' Sheets of Tin (A64912)
10' Sheets of Tin...
DIGGIT 72MM MULCHING HEAD (A65056)
DIGGIT 72MM...
