1969 3000 ford tractor
   / 1969 3000 ford tractor #1
Anonymous Poster
Epic Contributor
I HAVE 1969 FORD 3000 TRACTOR ITS HAS A SIMS INJ PUMP IT LEAKS FUEL OUT THE OVER FLOW AT IDLE. I CHANGED OIL IN PUMP DID NOT HELP ANYONE KNOW HOW TO FIX,OTHER THAN REBUILDING PUMP
   / 1969 3000 ford tractor #2
There is no quick fix. A pump rebuild is in order. Until then, drain off the fuel/oil mix as soon as you see it overflowing and refill with fresh oil to the proper level. No need of damaging the pump's cam and followers more than necessary.
2025 HOMEMADE GOOSENECK TRAILER (A58375)
2025 HOMEMADE...
10' Fork Extensions (A57149)
10' Fork...
2008 TEREX TRAILER LIGHT TOWER (A58216)
2008 TEREX TRAILER...
2014 Chevrolet 2500 Pick Up (A55272)
2014 Chevrolet...
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2223EB000633, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
New Holland T2420 (A53317)
New Holland T2420...
