3-Point Hitch 1970 MF 135 3 Point hitch adjustments after rebuild?
   / 1970 MF 135 3 Point hitch adjustments after rebuild? #11
This is a normal quadrant
Thank you, any idea why my control quadrant does not have a step in it like yours or the manual?
   / 1970 MF 135 3 Point hitch adjustments after rebuild? #13
Nevermore Farms, look at the BLACK label, it says PREASSURE. Read my post #4, this is what I was trying to explain. This setup has 3 functions on it.
Black for preassure control section.
Red for position control section
Yellow for draft control.
YOURS has 2 functions position and draft. Yours has a"red" and "yellow" equivilent. Being an earlier model it does not have a "black" equivilent.
Also look at the stops on the levers. The one for the draft control is missing, and there shold be a 2nd one on the inside quadrant. There was on my 135 that I sold. My 135 was an early model and had the same 2 function style of quadrant like yours.
Understood, thank you.
2008 Ford E-350 Passenger Van (A55852)
2008 Ford E-350...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
2018 HAMM HD 10C SMOOTH DBL DRUM ROLLER (A52707)
2018 HAMM HD 10C...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2018 KENWORTH T680 TRI AXLE DUMP TRUCK (A56138)
2018 KENWORTH T680...
