1971? Fiat no brakes?
   / 1971? Fiat no brakes?
WOW! Thankyou very much!!
That looks "edit* Almost" exactly what i have!!
I am almost finished the main shaft that holds the pedals, Might have to make some bushings to go through the gearbox yet..
In that picture, Number 2, which way should i adjust it to get more tension on the brake bands? As they were, from memory, only 1"/25mm screwed together, then locked with the nut. Should i wind them into each other more? Also the thread inside has rusted from dirt etc. Any idea what thread it is? Are these tractors normally metric threads?
   / 1971? Fiat no brakes? #24
These Fiats bear a striking resemblence to some of the earlier larger Kubota's. I believe there were some Fiat based Kubota models. Not sure if that info helps any.
   / 1971? Fiat no brakes? #25
You lengthen linkage to adjust the brake band. Be sure to leave about an inch of play at the pedal. And yes these are metric.
Ok thanks, I will have to remember this when i do it.
Thankyou very much everyone that helped me.
This brake problem was a great success!
I rebuild the whole brake pedal assembly shaft and bushes, retapped the adjusting bars to rid of rust/ dirt etc. Made up a tool to put the springs back on easy. (4mm stick welding rods are awesome).
We put it all together on Sunday, got her started after 5 attempts of jumpstarting a large flat battery :laughing:
Then i went and tested the adjusting mechanisms. THEY WORKED! My Dad and i were so happy!, He said it hasnt had brakes for 30yrs+!! So the bands are still working from original(no brakes = no wear on bands i guess) :laughing:
Made them equal adjustments on the pedals to it brakes evenly with the cross/joiner bar.
Yes it has been along time since the 1st post. I do work alot, and free time between my life and his, is very infrequent.
Thank you all again Champions! :thumbsup::thumbsup::D
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2019 Chevrolet Tahoe 4X4 SUV (A59231)
2019 Chevrolet...
2005 Komatsu HM-400 (A60462)
2005 Komatsu...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
2349 (A60432)
2349 (A60432)
