deere5105
Veteran Member
- Joined
- May 6, 2009
- Messages
- 1,086
- Location
- South Mississippi
- Tractor
- 2008 John Deere 5303 MFWD, 2004 John Deere 5205
Recently the temp gauge has been moving all the way to hot and staying there. Pulled radiator with intent to replace thermostat that might be sticking. Found that there was no thermostat in place. Since had one to ready to replace went ahead and installed it. Ran tractor again with same results. Picked up new temp sensor and changed it out. Ran tractor again with same results.
Tractor gives no indication it is overheating. From reading only other component involved could be voltage stabilizer which was replaced last year while troubleshooting a charging issue. All original components still in place and working as it should. Only issue is needle moving to hot.
Any one ran into this and found issue?
