1975 Ford 3000 power steering control valve issues
   / 1975 Ford 3000 power steering control valve issues #1
John Guy1
Iowa
John Deere 4020 Diesel, John Deere 830 Diesel
Hi,
We have a 1975 Ford 3000 power steering issue. It used to leak out of the steering column seals which where replaced and everything worked OK till recently the power steering stopped working.
We checked the pump output with it isolated from the system and it pumps approx 4 GPM at 800 PSI which should be to spec. When hooked up to the control valve it pumps through at 200 PSI, but it appears that all cylinder ports are under this pressure and it is harder to steer then without the pump running.
We have removed the control valve, cleaned it and reassembled. The groove in the control valve spool is toward the top. All plungers are free moving with the springs installed between them and the two check balls are inserted between the check valves. However this did not help the situation.
Anyone have suggestions? :confused:
John Guy
   / 1975 Ford 3000 power steering control valve issues #2
hunt down user ' Ultradog ' he is a member here.
He is the 'go to' man I always reccomend for them ford PS boxes.
Great, thanks.
As I am new to this forum, how do I go about getting hold of him?
John
   / 1975 Ford 3000 power steering control valve issues #4
send him a PM
   / 1975 Ford 3000 power steering control valve issues #5
Hey John,
I am curious to what you found out. Sounds like I am having similar issues. Putting the steering column back together (pump worked fine before i started the repair) get the point where i bleed the power steering system and its as though no fluid is getting past the control valve. Any info you might have got would be handy. Thanks!
Dan
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2020 Deere 325G (A50123)
2020 Deere 325G...
CATERPILLAR 303.5E CR EXCAVATOR (A52706)
CATERPILLAR 303.5E...
2014 Dodge 5500 4X4 Bucket Truck (A53473)
2014 Dodge 5500...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
