1975 IH 3500A hydrostatic backhoe/loader - will not go forward!
   / 1975 IH 3500A hydrostatic backhoe/loader - will not go forward!
The clutch must be depressed in order to shift forward to reverse - I wonder if the interlink has been damaged - the "never' you mentioned. I am looking into that now... I would love to actually USE this backhoe was it is half past May already.
UPDATE: Yesterday I had the time to remove the floor and the steering column protection. It looks like the cable between the shifter and the trans is the culprit. When shifting the mechanical linkage is not moving until I bypass the set screw on the column then there is a clunky shift. The good news is that the clunky shift made the vehicle go forward!!! The bad news is either the cable is bad or the linkage connection is bad. I am going to start with replacing the cable as it appeared to be separated behind the dashboard. Cross your fingers!!!
UPDATE!!! We have liftoff! The problem was narrowed down to the cable from the shifter on the column. The issue is the cable was unable to pull the lever/plunger into the trans to make it go into forward gear. I must have heated the trans up with low oil levels and effective "glued" the plunger into reverse post blown hose. PB Blaster and a lot of tapping loosened it to the point I could manually pop it up and go forward without the cable connected. NOW - I reconnected the cable and it still will not move the trans shifting lever and plunger so for the interim, I am going to add a manual "pull" to put it into forward. The regular shifter allows it to go into reverse easy peasy. Thanks for your feedback all this time... If anyone has any rube goldberg fix suggestions or permanent ones, I am all ears.
One final note - as older back hoe owners seem to know, irony is prevalent in their operation (so I am told). I go the unit going in forward and reverse and was overjoyed. Then, as soon as I went to use the dipper, I blew its hydraulic hose. All I could do was laugh.
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
