1977 ford 3600 trouble starting
   / 1977 ford 3600 trouble starting #1
Baby
Clarksville,tn
Ford 3600
Tractor was left out in the weather for about 4 years with cover over exhaust. This is a diesel tractor and I believe it may be seized up.
I was told by a friend to jack up the rear end, put it in high range and high gear and try to push or move a rear tire. Tractor is loaded up on a tall gooseneck trailer with a bush hog attached.
Any help would be appreciated....thanks...
   / 1977 ford 3600 trouble starting #2
I think I would remove the valve cover and make sure there are no stuck valves before trying to turn the engine over. Jacking up a and trying to jerk a wheel will work but I would rather put a breaker bar on the nut on the end of the crank shaft and pull it over that way. If you can bar it over two turns by hand I would hit it with the starter. You may also want to change all the filters and put fresh fuel in as well.
   / 1977 ford 3600 trouble starting #3
Pull the injectors and pour half a cup of Marvel Mystery oil down each cylinder. Let it sit for a week.
Then put a battery in it and bump the starter a couple of times. Likely that will unstick her.
If it breaks free and turns over it'll spew MMO everywhere but that can be cleaned up.
Concrete Hopper (A49251)
Concrete Hopper...
10ft Snow Pusher (A49251)
10ft Snow Pusher...
2022 Club Car...
2015 John Deere 5065E 4WD Utility Tractor (A49346)
2015 John Deere...
2013 Felling Trailer, 20'+5' Pintle Hitch (A47371)
2013 Felling...
12,000 LB Axle (pair) (A49251)
12,000 LB Axle...
