1978 White/Oliver tractor 2-85 NEED HELP
   / 1978 White/Oliver tractor 2-85 NEED HELP #1
DPic105
JD 990
This 2-85 had a 4wd unit added. I found the name Clark on the unit. The front right seal is leaking, are there any repair manuels out there for this front end?? Are there any speacial tools needed to change this grease seal??
Any hjelp would be apreciated.
   / 1978 White/Oliver tractor 2-85 NEED HELP #2
You might want to check the Hart-Parr Oliver's Collectors Association website. They have a forum there. If you are not a member of the "HPOCA" you should consider joining. For $25 you get a subscription to their magazine that includes a weath of information and parts sources.
   / 1978 White/Oliver tractor 2-85 NEED HELP #4
That would be the factory mfd axle. Check with your nearest AGCO dealer for the service manual.
17101 (A53421)
17101 (A53421)
ASCO Transfer Switch (A52377)
ASCO Transfer...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2015 Volkswagen Jetta Sedan (A53424)
2015 Volkswagen...
