1982 Ford 7710 FEL Control Change
   / 1982 Ford 7710 FEL Control Change
If you have a manual for the tractor, what does it say?
Tractor Data suggest that is is open center hyd system.
RickB says it is closed center hyd system.
The grapple might be easier with a diverter/selector valve.
With no voltage applied, the curl work normally, and when you want grapple, you press a button and curl lever now controls the grapple.
It is a used tractor, so I expect the manual was lost many years ago in some guys barn. I guess I need to order a manual for my model and see what it says about the hydraulic system.
I like your idea of a diverter valve on the curl function.
   / 1982 Ford 7710 FEL Control Change #13
DO NOT PARAPHRASE ME!
Nowhere did I say this tractor has a closed center system.
You yourself posted two separate links to Tractordata.com. One says a 7710 is open center, the other says it is closed center. Both together prove the value of that site's information. Neither is correct as the tractor has elements of both types as well as a CCLS system. It is a unique hybrid system.
A common diverter connected to a work circuit will function just fine.
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
5' S/A CART (A52706)
Dump bed (A51692)
Dump bed (A51692)
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A55218)
Ditch Witch 6510A...
