1990 John Deere 955, left brake stuck
   / 1990 John Deere 955, left brake stuck #1
ticowannabe
1990 John Deere 955
When I move forward it seems that the left brake is stuck, so much that if I continue engine will die under the load. Doesn't seem to stick in reverse. Any suggestions would be appreciated. At the moment I can't move the tractor.
   / 1990 John Deere 955, left brake stuck #2
The brake lining has probably delaminated from the shoe and is piling up under the lining on the other shoe.
Thanks RickB, but it's a hydrostatic trans and has no brake shoes. I appreciate your reply nonetheless. Scott
   / 1990 John Deere 955, left brake stuck #4
OK, you have wet disc brakes. Check the operating shaft and see if it is seized to the cover where it enters the brake housing. It should have several degrees of relatively free travel matching the pedal freeplay spec in your operator's manual.
kids dirt bike (A53424)
kids dirt bike...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
2011 JACK 130BBL (A53843)
2011 JACK 130BBL...
Utility Trailer (A52377)
Utility Trailer...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
