1992 John Deere 2355 Clutch problem
   / 1992 John Deere 2355 Clutch problem #1
I have a 1992 John Deere Cab and air with loader tractor. The other day while mowing I went to push the clutch in to stop and it went to the floor and kept going, finally got it stopped by forcing into neutral let it cool down and checked all fluids and they where all good. Two days later I went back to now with tractor and every thing worked fine till two hrs later I went to push clutch in and went all the way to ground and no way to stop besides forcing into neutral. Any ideas??
   / 1992 John Deere 2355 Clutch problem #2
Did you check the clutch master cylinder reservoir???
No, where is it located? The dealer told me it could be my master cylinder goin out and that would be the first thing to replace before splitting tractor.
   / 1992 John Deere 2355 Clutch problem #4
It's in front the dash. You'll have to remove the cowling(parts key #1) to access it. You're probably going get the experience what a PITA it is to bleed the air from it.
   / 1992 John Deere 2355 Clutch problem #6
PITA=pain in the hinny. Yes you can add brake fluid but if air has gotten into slave cylinder they are difficult to get the air out of them.
Oh ok gotcha lol... I'm goin to work on it Sunday after church hopefully just adding break fluid works I really appreciate it.
   / 1992 John Deere 2355 Clutch problem #8
If you have any problems bleeding then read this thread on another tractor forum. It has a lot of good information.
I appreciate the help I really do, what do you think of the 55 series tractors? Also my rpm gage is not working any ideas?
   / 1992 John Deere 2355 Clutch problem #10
The 55 series are great tractors. The only downfall with the cab tractors is difficulty working around the cab for alot of things. The cab needs to be pulled for a lot of repairs. Fortunately they were reliable and don't require a lot of repairs, but when they do, it gets expensive when the cab needs to come off. The tach not working could likely be the sensor which is in the front of the timing cover.
2023 Cub Cadet LX46 (A47307)
2023 Cub Cadet...
2012 Ford E-350 Cargo Van (A46683)
2012 Ford E-350...
2008 Hino 268A (A45336)
2008 Hino 268A...
2022 Bobcat ZT3000 52in Zero Turn Mower (A45336)
2022 Bobcat ZT3000...
John Deere TX Gator (A48561)
John Deere TX...
1979 Lincoln Versailles Sedan (A45336)
1979 Lincoln...
