1996 John Deere 425 transaxle leak
   / 1996 John Deere 425 transaxle leak
Ok I have ran the tractor with the tires off and jacked up. My question is I didn't want to go buy that expensive John deere oil for my transaxle so I put 5w-30 synthetic in it for my test. Do yoy think that will hurt it??
   / 1996 John Deere 425 transaxle leak #12
It's your dime...
but I wouldn't do that. I'd spend the $23 per gallon and get the Hy Gard low vis.
   / 1996 John Deere 425 transaxle leak #13
Well took your advice and blew all the crap out of there that I could reach with air. Lo and behold I looked down on the shaft for the parking brake and there was a seal that had popped out of the case. I took a very long and skinny pry bar and did my best to push it back in. I will rig up my gas tank tomorrow and run the tractor and see if it pops out again or leaks. I hope this fixes it? Thanks for your help I will let you know tomorrow how things go.
Thanks weeder
You could have cleaned out the area with some brake cleaner and blew it dry, then put a few drops of Loc-Tite on it to help keep it in place.
Well, no leaks so far, I will drain out the fluid and change out the filter and replace it with the Hy Gard oil. If the seal comes out again, I will replace it.
   / 1996 John Deere 425 transaxle leak #15
Have you checked that the vent is not blocked as suggested. You do not want pressure to build in there, it could pop out a seal.
Yes, I have, I cleaned all around it took the rubber vent top off and checked it out all's well there.
Entyre Chip Spreader (A51573)
Entyre Chip...
2017 INTERNATIONAL PROSTAR (A52472)
2017 INTERNATIONAL...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
