2.5"-3.5" Rod Hydraulic Cylinder-Where to buy?
   / 2.5"-3.5" Rod Hydraulic Cylinder-Where to buy? #11
The other thing to consider is the GPM flows increase on the return stroke proportionately as the rod displacement increases.....generally not a problem but return flow rate must not exceed the ratings of the DCV......
recently rebuilt a wood processor cyl 3.5 rod x 5.0 bore......they had a pilot-to-open check valve tee'd in to the base end port to drain off directly to the tank when returning....
I can't count how many 1.5" rods out of log splitters I have changed. Yes, they do bend in log splitters.
For the Surplus Center cylinder linked above, I'm sure a good hydraulic shop can custom make a cylinder for less.
Thanks. Do you guys think the 5x24x2 will be ok if I'm pushing a push plate and not a wedge?
Surely that ought to do.
   / 2.5"-3.5" Rod Hydraulic Cylinder-Where to buy? #13
yes that will do just mine. It doesn't matter if you are pushing a wedge or a plate, as long as you use something to keep it straight. Some splitters use a guide that sandwiches the beam others like your Huskee in your sig use the "log cradle" to keep the rod straight.
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
JOHN DEERE FC20M LOT NUMBER 55 (A53084)
JOHN DEERE FC20M...
