2- cycle multi-ratio oil
   / 2- cycle multi-ratio oil #11
I run by the oil manufacturer. They formulate the oil for maximum lubrication at a specific ratio. I personally run eith Husky or Stihl premium mix at 50:1. Thier little botles mix a gallon of gas; I only mix a gallon at a time and use it up so I typically have pretty fresh gas. Since my saws and trimmer are 14,000 rpm engines, I like to feed them premium gas too. My newer and older Husky and Stihl saws and trimmers run great with that mix.
There is a reason old saws used 16:1 or 20:1, is because the oils availble back then did not lubricate as well, or have the additives we have now. In many cases, the mix was plain 30w motor oil.
The most important this I have found, and was taught by a pro motocross racer, is use a good oil, good gas, and keep it fresh. On thier race bikes, they wouldn't use day old mix. Within 24 hours, the oil was breaking down in the gas, and lost some lubricity. Granted, they were talking expensive race engines, and winning championships.
If you run a richer oil mix, you won't help anything; just wasting oil. And smoking. An fouling plugs.
   / 2- cycle multi-ratio oil #12
</font><font color="blue" class="small">( My brush cutter calls for 50:1 and chain saw says 40:1; it would be convenient to feed both from the same mix. )</font>
It should be fine.
If it were mine, I would mix at 40:1 and run it in both.
That's what I do too. 50:1 should be safe, but I'm entitled to my little bit of paranoia :)
Chilly
   / 2- cycle multi-ratio oil #13
I use Amsoil Saber Professional oil mixed at 80:1 w/ 89 gas in all my 2-stroke equipment. From chainsaws to leaf blowers, it all runs excellent on it. Easy starting, great throttle response, and no smoke.
And I'm another saber fan.. Good stuff. It is rated to run 100 to 1
   / 2- cycle multi-ratio oil #14
Yep the Amsoil Saber is good stuff.
I run it in the same mix in my 2 Husky chain saws, weedeaters, blowers, the wife's mini-cultivator/tiller and anything else that calls for mixed gas. I run it at a 50:1 ratio and have been using it for years (the Amsoil 100:1 premix oil before they introduced the Saber stuff).
   / 2- cycle multi-ratio oil #15
Some engines can run lean on a oil rich fuel mix.
I've been wondering if someone would post that. It is true that more oil equals a leaner fuel air mix but I've gotten in so many arguments about this over the years I don't even try to bring it up anymore;)
Well known in the dirt bike world but seems unknown in most other 2 stroke worlds...
It seems counter intuitive that more oil can cause a seizure in a highly stressed/tuned 2 stroke but it can due to running too lean.
   / 2- cycle multi-ratio oil #16
I started using 100-1 Amsoil in a Stihl 07 chainsaw, give you Stihl fans an idea how old a saw I started out with. That saw never ran so good as it did with that 100-1 mix, and I do mix it meticulously at 100-1. I stress tested it by cutting blocks full bar off a pile of tree length wood on a hot summer day until I could hardly stand. The saw never missed a beat. Never fouled any more plugs. I finally pensioned it off when I couldn't keep all the other parts bolted to the engine. I bought a Husqvarna 154, that was almost 30 years ago. I have always run 100-1 mix in that saw and have cut a pile, a few piles actually, of firewood with it in that time. It still runs great, can't remember the last time I changed the spark plug.
So, for those who say engines won't last on 100-1 mix, I beg to differ.
   / 2- cycle multi-ratio oil #17
I run Shindaiwa oil mixed ~40:1 with premium gas in all of my 2-stroke equipment. Haven't had a problem yet. I'd use Stihl, Husqvarna, Echo, or any other name brand oil, but my dealer sells the Shindaiwa oil for less than half what other places ask for name brand 2-stroke oil.
2018 Gatormade 20+5 Gooseneck Trailer (A55301)
2018 Gatormade...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
2005 JLG Skytrack 8042 (A47477)
2005 JLG Skytrack...
