2 cylinders leaking thru intake valves
   / 2 cylinders leaking thru intake valves #22
Those pistons look like toast to me. I would not put them back into an engine I was rebuilding.
   / 2 cylinders leaking thru intake valves #23
I rebuilt the engine on my YM1700. I did replace the liners. (it is a 2 cylinder and they cost $340 each. Ouch!) Getting the old liners out was the hardest part of the rebuild to me. I could not find a tool either. So, I made one from a long threaded bolt and some angle iron. At first I kept bending the angles and the liners would not release. Someone suggested that I pack the liners with dry ice and then try it. It worked!
Having said all of that if the liners are useable I would probably try to use them too. I ran my tractor hot and there was lots of damage. I also replaced the pistons, rings, wrist pins, rod bearings, valves, stem seals, valve springs, and had the head re-worked by a machine shop. I also added a water pump kit. The 1700 does not come with a water pump.
Hopefully, mine should give me many years of good service now. Good luck with yours
Bob
$ 340 ea?
Danny
Looks like I've been shamed into replacing that piston too. :) Actually, I was starting to sway in that direction.
I'll be getting these parts on order-hopefully tomorrow. I'm looking forward to seeing how this thing runs afterward.
2007 Boston Whaler w/ Dual 200HP Mercury OptiMax (A51694)
2007 Boston Whaler...
Caterpillar GP40K Forklift (A52384)
Caterpillar GP40K...
AGT HPW3000-1 (A50123)
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2017 Polaris RZR 1000 EPS (A52384)
2017 Polaris RZR...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
