2 Inch Receiver On PT422 probably 425
   / 2 Inch Receiver On PT422 probably 425 #11
That looks great, Bob! Two great mods in a about one week -- is that a new record? :D
I am inspired by the comments here. Thanks for your encouragement.
I have attached a picture of the boat whinch. Basically I welded it to a 2 inch tube which fits nicely into the receiver.
Bob Rip
   / 2 Inch Receiver On PT422 probably 425 #13
Bob. There is all kind of stuff you can put into the 2 in reciever. They even have a plug in potty seat for those times you are far away. Platforms, electric winches, tool carrier, extra weight. I saw this vise mount someone made up. I am sure you will come up with many more. Nice work.
I actually needed the vise a few years back while replacing the septic tank pump. I have a spare vise and may do this. Actually maybe I could weld it to the same bar that the winch is on. Then tie it across the bumper for weight when I am not using it.
I tried lifting the PT with the winch on the receiver and it worked pretty well. Both wheels got off the ground at one time, then the PT rolled back a little bit. See attached. I guess it's strong enough. The 3/8 bolts seem a little small. Any thoughts on this.
Bob Rip
   / 2 Inch Receiver On PT422 probably 425 #15
Bob. I think I would go with a larger pin, like 5/8, or 3/4 in grade eight.
I checked on the strength of the 3/8 bolt and it is about 2000 pounds. This seems like enought, so for the time being it is low on my list. Of course that means I will probably fix it when I take it off for the next set of modification and paint it. I want to put the wood bumper on.
Bob Rip
Attached is a picture of the wooden part of the bumper and the support metal brackets for it. The brackets will actually be welded to the 2 inch receiver and then the wooden bumper will be mounted on top with lag bolts going up through the wood. The metal is some scrap that I had.
Bob Rip
I finished the welding in these pictures. At this point I am putting the metal on to hold the bumper. Most people probably will not use the bumper, so the extra metal is optional.
I wish I had added places to attach chains to like on most 2 inch receivers. This would also give tied down while trailering.
Bob Rip
   / 2 Inch Receiver On PT422 probably 425 #19
Bob, The pin hole looks larger that 5/8 in in the last picture, did you go to a larger hole?
It's stock, but I think it's 3/4 inch. I am going to use grade 8 3/8 inch bolts to connect to the PT. I got some 5/8 inch, but they would make too big a hole.
Bob Rip
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2015 FREIGHTLINER...
JOHNSON 5 1/2HP SEAHORSE OUTBOARD MOTOR (A58374)
JOHNSON 5 1/2HP...
