2 row planter
/ 2 row planter #1
brown1
grass lake mi
bobcat ct235
am looking to buy a 2 row planter preferebly set up for 3pt. i know you can get used ones on craigslist but it seems they want a sorts of dime for very used ones. does anyone make these new? has anyone bought a newer one and how are they? i know todays quality isn't near the older ones so but they want the price of new. oppinions please and thanks in advance for any advise.
/ 2 row planter #2
To me, the most important thing to look for in a corn planter (new or used) is that it has "real" fertilizer attachments. This is a big money saver down the road, as it lets you get all the fertilizer (including nitrogen) that the corn needs for very good yields, as you plant it. This is especially true if using RR corn seed, where all the weed competition, in the rows, can be wiped out later, while cultivating. At planting, simultaneously, all the fertilizer is buried, right next to the rows, where it is most needed. There is no need to wait until "right before a rain", or waste most of the fertilizer between the rows as is the case if a broadcast spreader is used.
The reason I say "real" fertilizer spreaders, is you have to look out for folks pushing "insecticide applicators" as "fertilizer applicators", especially on the very popular JD model 71's. An insecticide applicator has neither the volume, rate capacity, or corrosion resistance to be used on fertilizer. You will know you have a "real" fertilizer applicator if the fertilizer hopper is larger than the seed hopper.
It is quite difficult to locate an old, used planter with functioning fertilizer applicators. That is because fertilizer is so corrosive and most have rusted out years ago. I was lucky to find an old 3-pt JD model 246, with good fertilizer applicators, many years ago. I have been very careful to clean it good after every use so that the fertilizer attachments remain good. If you are unable to locate a planter with fertilizer attachments, another option is to locate an old cultivator tractor (Like a Farmall Super-A or Cub) that has a good side-dresser. That is not quite as good of option as the planter because it does not give the corn seeds the "startup" boost that they really could use.
/ 2 row planter #3
Pequea still makes a very nice 2 row, based on JD Max Emerge units, but they are pricey. Are there any boneyards in your area? We have a couple within an hour. If I was looking to buy or build, I'd call these guys. Sometimes you can find a wrecked 4-row or more planter with good, salvageable row units. I've driven past Fry's Machinery, Inc. a couple times looking for certain items, and they have a pile of older planters. What are you intending to plant? If corn only, Allis Chalmers plate units are indestructible, and can use IH plastic plates(16 or 24 cell) for different seed sizes, and they are ground drive. They can't be sped up enough for soybeans, green beans, etc., but JD 71 units and Max Emerge can.
As far as the fertilizer attachments, most of that era are rusted out and frozen up. The ones with good fert. components are rare and priced that way. Liquid starter is always an option. Plastic tanks and ShurFlo pumps are reasonably priced. We went that way when the fertilizer tanks on our planter finally rusted out.
/ 2 row planter #4
It just a matter of what you are willing to spend. Yetter is still making the JD 71 row units, but under their name. The 71's are among the best plate planters every made. If you are wanting new dry fertilizer boxes to go with it, the guys down at First Products can hook you up with a set of stainless steels ones.
As others have said, you can also look around for a good used set. I have seen some guys that are cutting down older JD 7100 planters and making 2 row set for sale. Nevertheless, it's not hard to rebuild the row units if they need it. I bought a 6 row set of JD plateless planters at an auction and then ran them through my shop (disassembled , sandblasted, paint, new bears, idles, chains, decals) and probably saved myself $10k +.
71 Series
1stproducts.com
/ 2 row planter #5
Re; 71 Series.
Looks good, fertilizer box must be an option. My preference would be the trailed model.
/ 2 row planter #6
A new cole 2 row unit is 3K. If you could get a similar quality used unit for 50% of that, you would be doing good, imho.
/ 2 row planter #7
I bought a refurbished dual JD 71 Flexplanter off eBay for $1K plus about $300 shipping from Minnesota to Northern CA.
Yetter makes their version of the 71 now.
You can add fertilizer boxes as mentioned earlier in this thread.
Good luck
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2001 FREIGHTLINER CST120 (A63569)
2001 FREIGHTLINER...
Kubota L3901HST
Kubota L3901HST
Dodge Charger (A56859)
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
