2 Stroke Fuel/Oil Mixing Guide
   / 2 Stroke Fuel/Oil Mixing Guide #11
Champy, you have those goofy little bikes, they dont count :D
For my 2 cents anytime you change your mix ratio's substantially, you will need to rejet. One of the things I try and get folks to do, when tuning, is to try and eliminate as many variables as possible, same gas, same oil, same ratio's, then start jetting and tuning according to what they want to run.
I run at 72 to 1 so that when I use team gas, my bikes are right :cool:
To be honest, I don't think I have seen anyone rejet a chainsaw or weedeater carb other then the competition chainsaws.
We run our two stroke Lawn equipment on the 40 /1 bottles I think they are that come pre-measured, so there is not much thought in the filling process..... Except the time Hanna decided to just put straight gas in a premix can and uh,,,, add the oil later :mad: One $350 weedeater later.................
   / 2 Stroke Fuel/Oil Mixing Guide #13
Here is the chart that I made. The chainsaw, weedwacker and other engines all take different ratios. I usually mix 1 gallon at a time.
  • gas-oil ratio.pdf
   / 2 Stroke Fuel/Oil Mixing Guide #14
Champy and L3650:
Thank you for the charts :D! I have never met a grid or graph that I did not like ;). Jay
   / 2 Stroke Fuel/Oil Mixing Guide #15
I mix all my 2 stroke fuel/oil mix at what the manufacturers recommend.
Poulan sells and I use synthetic oil and instructions are to mix it to the same ratio as the regular oil.
Why take a chance ?
   / 2 Stroke Fuel/Oil Mixing Guide #17
Wally world also sells a syringe type of thing to get an exact measure on your oil for your mix.
2011 JACK 130BBL (A53843)
2011 JACK 130BBL...
TORO TR20 WALK BEHIND TRENCHER (A51406)
TORO TR20 WALK...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
