20 hp B/S opposed twin surging
   / 20 hp B/S opposed twin surging #1
AroniaFarmer
Sioux City IA
TYM T603 52' Ford 8N
I have a opposed twin cylinder 20 hp engine that will run great for about 15 mins and then start to surge. The surge will go away if I pull the choke a little.
   / 20 hp B/S opposed twin surging #2
Sometimes adjusting the tension on the governor spring will help??
If the carburator has adjustment screws try making slight adjustment.:eek:
   / 20 hp B/S opposed twin surging #3
With the good gas that we recieve thanks to our government we are cleaning the carbs as quick as people bring them in. I don't know for sure at this point but I might agree with it being the governor spring which is a typical briggs issue.
   / 20 hp B/S opposed twin surging #4
Surging is usually caused by too lean a mixture. Try some enrichment on the main jet.
   / 20 hp B/S opposed twin surging #5
True, but OP says it runs ok for a while before it starts to surge. I'd suspect some trash in the carb that is getting sucked up in/next to the main jet after it runs for a while. Does the carb have a removable bowl? If so, remove, rinse it out, and replace.
A good dose of Sea-Foam also couldn't hurt.
   / 20 hp B/S opposed twin surging #6
If it runs OK for 15 minutes check the fuel tank cap - if the vent is plugged this is a symptom I have seen - runs fine for a while then starts to stutter. Clean the vent. Then clean and adjust carb as next step..
Carl
   / 20 hp B/S opposed twin surging #7
Clean the carb really really good and it wouldnt hurt to flush the fuel tank and lines. If it still does it after that you should look at the fuel pump, its probably on the way out.
   / 20 hp B/S opposed twin surging #8
Same thing with my briggs 14.5 twin. Worked on it today with carb cleaning.
Didnt help.
What i did discover though is that if the tank was full, the fuel is above the pump and gravity fed. 15minutes later, the fuel is now at pump level and the surging starts.
Replace your fuel pump.
   / 20 hp B/S opposed twin surging #9
I would look for a vacuum leak.
   / 20 hp B/S opposed twin surging #10
Same symptoms as my B&S twin . I bought the B&S carb rebuild kit and did the rebuild. Runs smooth as silk. I used a can of carb spray with the little straw to blow out all the jets and passageways. Whole job took less than an hour.
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
