2000 ford three point hitch
   / 2000 ford three point hitch #1
Varmint1
Deville,La
JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
My uncles 67 model 2000 ford 3 cyl. gas three point hitch only works if he moves the draft control and then it just lowers back down
   / 2000 ford three point hitch #2
time to buy an fo-31? service manual.. a 15$ top cover gasket and oring kit.. and pull the cover and adjust the linkages renew the orings and gasket..e tc.. might service the filter /oilwhile in that far as well.
   / 2000 ford three point hitch #3
Soundguy- Does a 1963 Ford 2000 have a filter in the 3 point lift system?
Thanks- Oldstuff
   / 2000 ford three point hitch #4
Thanks- Oldstuff
short answer.. no.
long answer: could be.
1, there was a dealer filter option available that used an external spin on filter.. they are exceedingly rare to find on that has that option.
2, if you are running some sort of hyd implement off the tractor hyds, if there is a return filter on that setup.. then defacto.. the system has a filter.
run of the mill 00/01/4 cyl 000 no filter..
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A53473)
2015 RAM 5500...
2013 W-W TRAILER ENCLOSED TRAILED (A53843)
2013 W-W TRAILER...
Honda Pressure Washer (A53117)
Honda Pressure...
2005 YALE 5K FORKLIFT (A53843)
2005 YALE 5K...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A53117)
2018 Mack PINNACLE...
