2001 873 leaking out of the back side of the control valve
   / 2001 873 leaking out of the back side of the control valve #1
chris maggio
Does anyone have any info on what needs to be replaced ? is it an O ring in the valve ? does the whole valve need to be taken out or can I do it in the machine ? any step bye step would help thanks ! Chris.
   / 2001 873 leaking out of the back side of the control valve #2
Unless the spool is scratched or worn it should just need seals. Take the linkage pin loose at front of the valve, remove the 2 screws holding the centering cap on at back of the valve and slide valve out the back. No need to remove the complete valve for spool seal leak only.
You can buy the seals in a kit per spool (1,2,or 3 spools).
2019 Nissan Versa Sedan (A55853)
2019 Nissan Versa...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
CATERPILLAR D8T CRAWLER DOZER (A52707)
CATERPILLAR D8T...
EZ-GO Electric Utility Cart (A55853)
EZ-GO Electric...
2017 Ford F-350 (A56858)
2017 Ford F-350...
2015 Dodge Charger Sedan (A55853)
2015 Dodge Charger...
