2002-BX2200
- Joined
- Mar 28, 2007
- Messages
- 13
I know that it is hard to believe, but I have owned my BX2200 for five years and never checked alignment of the MMM until this weekend. The left front anti-scalp wheel was worn completely flat, the right front wheel was worn about 50%, but the back two wheels were near perfect. After being shocked at the cost of replacement wheels, I was told that the wheels should not make constant contact with the ground. It never occurred to me that something was wrong because the cut height on the used B6100 that I had previously owned was set by setting the height of the wheels, and because, even out of alignment, the BX2200 cut so much nicer than the B6100. Additionally, I had the dealer service the tractor annually for the first three years, so I had assumed that everything was setup and tuned correctly.
Anyway, while I will admit that I am not much of a mechanic, the instructions for aligning the mower were of little help. The tech writer who wrote them must have had a substance abuse problem because they are close to undecipherable. It took me all weekend, but I did manage to figure out how the deck is aligned.
With that said, I found a few things that bother me beyond belief. The first is that whoever assembled the deck did a horrible job of installing the sway bar. They had the bottom washer on the left-hand side of the deck cocked in the slot such that half of was below and half was above the slot in the mounting bracket, resulting in the bolt cutting a shallow groove in the mounting bracket. I ended up having to remove the sway bar (which is simpler than it looks) to fix this problem. Another problem that I discovered is that mower height cannot be made to match the height on the dial. The closest I could get it was within 1/8 of an inch by screwing the right lift arm linkage all the way down, but then the lift mechanism would not go high enough to lock the mower in the "top" position. As no matter how much the mower is adjusted there is a 3/8" difference between the left and right stops, I am assuming that the right stop is too low (has anyone had to adjust their stops?).
In closing, I learned a lesson the hard way, and, that is, never trust a dealer to do the work correctly. While the owner may be a “straight up” guy, the guys in the shop may be clueless idiots or just plain lazy. IMHO, with an $11,000.00 price tag, there was enough margin in the sale to set the machine up correctly (and, at $350-$500 each year for annual service, this problem should have been caught). Also, if I had known what was involved in keeping this thing running and setup correctly, I would have purchased a large homeowner-friendly garden tractor. IMHO, the BX is the worst of two worlds. It has the maintenance schedule of a compact tractor without the power/strength of compact tractor, and the build quality on the new Kubotas is nothing like it was on the older ones—not even close!
