2003 John Deere GX345 Low Oil Pressure Warning Light
   / 2003 John Deere GX345 Low Oil Pressure Warning Light
Ok, so I have finally gotten around to changing the oil. Changed oil, and filter. Tried to start it and I run full throttle and full choke for about 10 seconds and then it will die off. It fires right up no problem but as soon as I try to bring down the choke any it dies and shows the low oil pressure light. I'm not sure if that's correct function or not but do you all have any recommends?
   / 2003 John Deere GX345 Low Oil Pressure Warning Light #12
How about the air filter?
Been changed?
   / 2003 John Deere GX345 Low Oil Pressure Warning Light #13
As previously stated . Measure the actual engine oil pressure and set point of the low pressure switch . Using 5W-20 oil , 15W-40 or straight 40 weight ?
   / 2003 John Deere GX345 Low Oil Pressure Warning Light #14
This sounds like a different problem than the original problem ----- a fuel problem rather than a "low oil pressure" problem. First step is to define the problem ----- or help us to define the problem. A fuel problem could be a fuel supply problem (fuel pump or restricted supply lines) or a carb problem. Or as mentioned in a previous response, could be a plugged air filter.
What do you mean by "set point of the low pressure switch" sorry just trying to understand. ;)
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2 Disc Heavy Duty Bottom Plow (A51573)
2 Disc Heavy Duty...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
WB Mower (A50120)
WB Mower (A50120)
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A52472)
2018 WACKER NEUSON...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
