2005 44 inch zforce right side hydrostatic slow
   / 2005 44 inch zforce right side hydrostatic slow #1
Jhicks427
Burlington, ky
Cub cadet
Left side works fine forward and backward. Right side is very slow both directions. Adjusted the linkage but still the same issue. Any suggestions?
Any help?
   / 2005 44 inch zforce right side hydrostatic slow #3
Jhicks427,
Since you readjusted the lap lever first (which is what I would have done) and it made no difference, I would check for leaking seals on that drive. If you discover same, the drive requires a refill, at the least, and perhaps new seals and gaskets.
Next would be a tear apart of the drive to see what the internals look like. I have read that small metallic particles can plug various fluid valves in the open position, lowering the speed and power of that drive. A simple clean out was all that was required for a fix.
All of that said, you can find your drive make and type (Hydro Gear, etc.) and serial numbers on the body of the drive. A search online should find the correct repair manual in pdf format or as a zipfile. I was able to find the drive manual for my ZForce 48 back 6 months or so ago.
Some drives are rebuildable, if you have the tools, the shop, the time, and are a reasonably skilled backyard mechanic. Some drives are simply throw away's, as in many RZT's. You won't know which you have, until you find the drive specifics (model and serial #'s) and do some searching. If you are a DIYer is the next answer. After all, it doesn't work now, so nothing's lost from trying and not being successful.
Short of that, your next step is eBay, parts suppliers, other independent small engine shops who scavenge old units for parts (as many makes use the same drives), etc., or going new from Cub Cadet.
Good Luck!
   / 2005 44 inch zforce right side hydrostatic slow #4
Good chance the hydro drive is done.
Search this forum for numerous similar stories. I, like many others, had the hydros fail at about 200 hours. My dealer confirmed this as common with the RZT. They are not rebuildable - throw away. The cost of replacements is over half the price of a new machine. Cub had no sympathy, despite the failures being well documented on web sites like this one.
My experience was with a machine from a few years back, about the same timeframe as yours. One would hope that Cub corrected the design flaw since.
   / 2005 44 inch zforce right side hydrostatic slow #5
did you check your belt?
   / 2005 44 inch zforce right side hydrostatic slow #6
Check the belt and that the spring loaded idler moves freely.
   / 2005 44 inch zforce right side hydrostatic slow #7
i do believe that unit uses tranny filters ,check it to see, try draining oil (pretty hard changing filter without loosing oil. on a 05 might need changing (make sure you know how to bleed tranny after your done) i had a customer with a enforcer with same symptom's seemed to fix problems
   / 2005 44 inch zforce right side hydrostatic slow #8
Its been a while but am interested in how it went?
I also need a fellow Z Force owner to help me out with a picture of a wiring connection behind the seat.
Mine is a 44" with the Briggs and Stratton 18HP Intek. I am in the process replacing it with a 23 HP Intek.
I have an issue with what was connected to the termination under the big red wire in the pic below.
The color of the wire(s) A Cell phone pic would be great. Its right behind the seat.
IMG_20131106_105210_zpsded63b75.jpg~original
   / 2005 44 inch zforce right side hydrostatic slow #10
Thanks!
Very good stuff.
I am trying to figure out where the double red wire termination goes. I am migrating a 23HP B&S into the 18HP's place and the wiring termination is different. The new motor is a 445577-6187 G5.
I figured the gray is the furl cutoff. The black is ground or motor cutoff?
It looks like I tie all the reds to the new motors red side. But the double red wire has me perplexed. I think it for the oil cutoff 98db speaker I hooked up but shame on me for not documenting better at disassembly. I'm going to be very careful with it.
Any help with the wiring would be great.
wiring_zpsac00b395.jpg~original
Work In Progress
IMG_20131107_111140_zps966c2609.jpg~original
Much better air filtration then the old 18HP that lost a cylinder.
IMG_20131107_111045_zpsfbb343c0.jpg~original
intek_headgasket01_zps668b9a5f.jpg~original
A Before Pic / I added the Right side tank when I purchased it. Its the first year they came out with the Z Force.
zforce_10_years_old031200_zps2ec83f36.jpg~original
   / 2005 44 inch zforce right side hydrostatic slow #12
Thanks, Thats the engine side. Now how to hook the mower side to it. I updated my pic to show the magneto wire as shown on the CC Mower schematic.
Looks like I connect all the red wires to red, a ground to black, and the fuel solenoid to the gray.
   / 2005 44 inch zforce right side hydrostatic slow #13
Thank You Old Machinist!
The vendor "Small Engine Suppliers" had already provided me the same .pdf but you sent me to the correct page. The manual was a real treat also. Both were Life Savers.
I wound up with a much cleaner configuration only needing the Yellow (Magneto Ground), one Red wire, a jumper, and the ground.
The 5HP jump will be nice. In 2003 when they 1st came out with Z-Force they had the 15HP Kawasaki and an 18 HP B&S options, they followed up in 2004 with the 20 HP B&S and I knew why. It labored in anything but ideal conditions causing one to slow it down a bit but still a great mower. With about 30% more HP I should be good to go.
The Tiny Tach Tt2A reports a little more than the No-load 3300 RPM,and it idles @ 1750. Its using the same muffler but seems much quieter.
Can anyone get me the no-load RPM for the 407777 0128- E1 Intek 18HP? I cannot locate it.
Thanks!
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
2021 CATERPILLAR 926M WHEEL LOADER (A60429)
2021 CATERPILLAR...
