Do you have a DK55 or DK55s? I think the original DK55 operated 4WD mechanically but my DK45s uses a hydraulic solenoid. Sounds like you have the solenoid version? If so, I'd try applying 12v directly to the solenoid to see if the hydraulic part is working.
Supplemental: If you are not sure of your exact model, give us the first four digits of the serial number. The first digit indicates the build year and the next three indicate the specific model. There are several flavors of DK55 (DK55, DK55s, DK55se, etc.). But even within each of those there were production changes. For example the DK45s came with two different engines, depending on serial number. The older service and owners manuals manual contain errors and are sketchy (not much detail) but they are available.
