2005 GT2254 carb linkage for 22 hp B&S motor
   / 2005 GT2254 carb linkage for 22 hp B&S motor #1
clovergamecock
Clover SC
Kubota L2800 4WD FEL
I don't know if something fell off or is bent but the engine now runs either wide open or barely idling. The adjustment screw has no affect and the arm at the bottom of the carb bounces. Any ideas or pics of the assembly? Choke works fine and the throttle cable is in the same setting it has always been.
Wade
Looks like the Engine is a Briggs, Model No. 40H777
   / 2005 GT2254 carb linkage for 22 hp B&S motor #3
From what you have described, I'm guessing, and I could be wrong, it's a governor related issue.
Here is another thread that discusses a governor issue on a B&S 20 HP intek engine, not exactly the same engine that you have but very close.
There seems to be similar issues to what you described.
There are some photos, that may at least give you an indication if something is missing or not, maybe it will help.
http://www.mytractorforum.com/12-john-deere-forum/203373-scotts-rider-problem.html
Great info! I will try this today. Thank your for sharing.
Wade
PAIR OF VACUUM PUMPS (A53843)
PAIR OF VACUUM...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2018 FREIGHTLINER...
2008 Ford F-250 (A53473)
2008 Ford F-250...
