Hey,I hope everyone had a great Thanksgiving. I received the new fuel solenoid timer control module yesterday. I found time to install it today, and it did resolve the issue. Also, a new pto switch and it now functions as it should.
I am experiencing the same issues with my 4210 that it seems like you solved with you 4410.
Great write up and thanks for following through! I hate when a thread goes silent with no resolution.
Anyhow, I also think I am at a point of the Fuel Solenoid Timer Module. I have spent the last couple days testing the solenoid, K2, K3, K4, the Diode and the what I could of the timer. I get the initial "pull-in" when I turn the key but it cuts out after the 3 or so seconds. Therefore, it runs until the solenoid cuts out. Checked the continuity on all the wires, followed voltage through the relays, and the ohms on the solenoid harness. I can rule out the Neutral and the Seat switch by using a jumper wire.
Last bit I could try before throwing down money on the Module is the PTO switch... However, I'M guessing if that was bad then I wouldn't get the "pull-in" voltage.
Again. Thanks for the write up... after reading a couple dozen others this was the most helpful and complete!
