dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,609
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
MadReferee said:It would be impossible. You can't have the spools of a single valve working from different hydraulic sources. You would have to have multiple valves with multiple hydraulic sources.
If you want a backhoe that operates multiple functions simultaneously, the only cosrt effective way to accomplish this is to purchase a TLB that has multiple pumps and multiple valve blocks for the backhoe (ie. an L48).
I agree, impossible with one valve. Now with 2 valves and a PTO pump
as a 2nd pump, it is an interesting project. $500 for the PTO pump and
res, and $500 for a second Prince stack valve pair. Way cheaper
than an L48 or L39.
Since a CUT hoe uses a stack valve, two valves can be removed from
the existing stack and another independent valve can be installed
next to it. The problem I see is that to use joysticks, you really
need to put 2 circuits on each pump and be able to fit the 2 independent stack valves under the b/h panel. Not a lot of room to work with.
I personally have learned from many hours on one-pump hoes how to
be very productive with feathering my valves.
