MVTractor
So I致e been bitten by the clicking solenoid bug and have searched far and wide for a solution and need one before I screw up everything. No signs of problems ever, then the other day tried to start and only a click. Trickle charger shows green, been on all winter, old battery tester reads good even on load, digital reader shows battery good so do the usual clean battery posts, starter pos line, and grounds, Still nothing, no lights, very dim dash lights, turn ignition and dash lights go out. pull off lower cowl check contacts all good, no corrosion, add dielectric grease to contacts anyway. Check relays on left side all look clean so grease and replace. Nothing. OK reading about issues inside the battery cables so bring out my battery charger/starter, disconnect battery terminals and apply charger to lead clamps. Get lights to dash and headlights but solenoid keeps clicking until I release the ignition key So one last shot Negative wire from charger to a solid frame contact and positive from charger directly to the positive post on the starter. Good lights on dash, headlights work as should but solenoid just continues to click until I release the ignition. I am guessing solenoid or starter but have not yet removed starter to get to the wires behind. Less than 300 hours and always garaged wouldn稚 you think it would be equipment failure and not bad contacts? Anyway have seen something about a white wire off the starter but not sure what that entails, Could use some direction as this is my first tractor and lots of Greek between the lines.
