2006 TN75AA 4WD
   / 2006 TN75AA 4WD #11
well i know this i feed 7 bales of 5 by 6 hay a week.where if i was feeding the 4 by 6 bales id be feeding 10 a week or more.an if i was buying the same hay 5 by 6s would be $280 a week vs $450 a week.
   / 2006 TN75AA 4WD #12
Big bales are great if you don't have to truck them; not everyone here lives in Texas. In many states, hauling 5' bales two wide will get you fines worth more than the load just about every time.
   / 2006 TN75AA 4WD #13
In regards to clearance, are you referring to the winrow's when round baling? The one I found is a 4wd, does it have better clearance?
Correct, the windrow hits the bottom of my TN75 which means I can't bale with it. We also have a Kubota M7040 (same PTO HP) that is 4wd that stands taller. We bale with the 4wd and do everything else with the TN75. On the other hand I can do things with the TN75 (because it sits lower) that I can't with the M7040. Pro's and Con's in everything.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2006 Ford Explorer 4x4 (MPV), VIN # 1FMEU73E36UA28575 (A51572)
2006 Ford Explorer...
2022 KMC 21-39-HD LOT NUMBER 197 (A53084)
2022 KMC 21-39-HD...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2015 HINO XJC740 BOX TRUCK (A52576)
2015 HINO XJC740...
