2007 models still available
/ 2007 models still available #1
SierraWhiskey
Hello all...new to the site and new to tractors. Would really appreciate your help on a couple of questions:
There are a number of dealers around that still have unsold 2007 models, with full warranty and pricing seems to be very good because they have sitting for 2 years. So what concerns should I have, what to look for, etc. It seems it is not uncommon to see 2 year old tractors with low hours with good prices, which means they have been sitting around as well. Thoughts?
I have 35 acres at 7600 ft in elevation, very rocky and for the most part level. Looking for general maintenance, need to move a lot of rock, some small boulders (we had to blast 1/4 mile to get ultilities to the house), remove stumps, dead timber, snowplow, etc. No horses, but you never know. I have been looking at 50hp tractors ( Kubota L5240 w/ FEL and BH90). Most folks around here seem to get buy with 30-40 hp. What are your recommendations?
Thanks in advance for help,
Steve
/ 2007 models still available #2
I got a great buy on this left over 2005 with only 2 hours and full warranty on it.
There are a number of dealers around that still have unsold 2007 models, with full warranty and pricing seems to be very good because they have sitting for 2 years. So what concerns should I have, what to look for, etc. It seems it is not uncommon to see 2 year old tractors with low hours with good prices, which means they have been sitting around as well. Thoughts?Steve
/ 2007 models still available #3
I bought a MF 5 or 6 years ago and last year a Montana that where over a year old and both where considered demo tractors. It is not really uncommon to find tractors around like that are 1 and 2 years old. I would make sure they did at least an oil change and possibly a coolant service as part of the sale. Other than that they should be fine other than a maybe a bit of faded paint.
A 30 to 40 hp tractor with a FEL and MFWD can do quite a bit of work. Around 50 hp you can start getting into the utility tractor line instead of the compact tractor(depending on brand/model). A utility tractor is generally built heavier than a compact. Depending on how much loader work you want to do that may be an advantage.
/ 2007 models still available #4
Good Afternoon LB,
Nice little Kubota but I think its lacking a bit for the 35 acres the OP has. Heck Ive got 10 acres and I would like to upgrade to 40 hp eventually JMO ! :)
/ 2007 models still available #5
I think a 50HP 4wd tractor would probably be in line with what you want to do. You're in the utility tractor range but you get the ability to to a larger job without risking tearing up the machine. It also allows for a larger selection of implements such as you probably won't find a rock bucket for a smaller tractor that can lift some of the rocks (or quantity) that you made need to move. IMO I think you have more options.
/ 2007 models still available #6
Steve
50. Big mountains - big tractor.
/ 2007 models still available #7
Steve
Age on a tractor means nothing except to Yuppies. Hours is what matters.
Andy
/ 2007 models still available #8
Andy
I agree. If you are getting it from a dealer and it has the full warranty there should be no problem. It sounds as if yoou have found a good deal. Go for it.
/ 2007 models still available #9
At your elevation I would look for a turbo model or at least the largest engine in a given frame size. It will be making less hp than us low landers.
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
2014 Ram Pro Master 2500 Cargo Van (A66736)
2014 Ram Pro...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A69167)
2001 FREIGHTLINER...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
CAT 963 4-in-1 Bucket (A68134)
CAT 963 4-in-1...
ROBINAIR MODEL 34788NI AC RECOVERY UNIT (A67714)
ROBINAIR MODEL...
