2007 New holland TC40 starting issue .
   / 2007 New holland TC40 starting issue .
Well **** it I thought I was fixed . Back to the same issue . Guess the starter is next .
   / 2007 New holland TC40 starting issue . #12
I feel your pain. My NH1920 has electrical/starter problems galore. I replaced the starter only to find the original starter was fine; installed push-button shunt between the starter post and solenoid, which has now quit working; have used the 'sparky' screwdriver shunt between the starter post and solenoid; rodents chewed my dash wiring harness in half. Replacing the electrical relay parts that Mike Ward shows on this posting https://www.tractorbynet.com/forums...rd-1920-not-starting-not.html?highlight=relay has been the most help. If your TC40 has similar relay sets, it might help to replace them.
   / 2007 New holland TC40 starting issue . #13
check your safeties
especially the seat safety
i messed with mine (tc45d) for a year and a half. ended up replacing several small electrical items each time it seemed to fix it fir a short time. the seat safety kept testing good but i changed it out of frustration and problem has gone away for 3 years so far
good luck
   / 2007 New holland TC40 starting issue . #14
honestly instead of just throwing parts at it, do a voltage drop test with your meter, it can potentially save you a lot of money.
After all said and done the starter had to be replaced . I’m going to tear the old one apart and see if I can rebuild it .
2011 GMC Acadia SLE SUV (A53424)
2011 GMC Acadia...
2018 Caterpillar D5K LGP Crawler Tractor Dozer (A55787)
2018 Caterpillar...
2014 BMW 328i Sedan (A55758)
2014 BMW 328i...
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
