2008 L3240
   / 2008 L3240 #1
JoeL3240
I have a 2008 L3240 HST Tractor. The Front Differential case is supposted by the Front Axle Support and the Rear Axle Support. I can not seem to get grease into the Rear Axle Support. I have removed the grease fitting and pumped grease through it so the grease fitting works fine. With the grease fitting off I have removed all the grease from what appears to be a blind hole about 3/8" in diameter by about 5/8" deep. Is there any reason why I can not get grease into this Front Differential Case - Rear Axle Support. The Front Axle support once I remove the air plug takes grease fine.
   / 2008 L3240 #2
I have same problem on my 2009 L3940. I do not understand why Kubota did not put removable plug on rear like they did on front?!? You may want to move this to the Kubota owners and operating forum here. Let me know if you figure it out. Philip.
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
LEEBOY PF1510B ASPHALT PAVER (A51406)
LEEBOY PF1510B...
2011 INTERNATIONAL DURASTAR 4300 M7 BUCKET TRUCK (A51406)
2011 INTERNATIONAL...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
2015 INTERNATIONAL 4300 26' REEFER BOX TRUCK (A54607)
2015 INTERNATIONAL...
