sawtooth
Veteran Member
- Joined
- Sep 19, 2007
- Messages
- 1,192
- Location
- Eden NC
- Tractor
- Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
Guys,
I bought this tractor knowing it has a brake issue but the price was right. So it’s a 4x4 with cab and front loader. The issue is the right brake seems to grab a bit (not always) and the pedal is hard with very little movement. I can tell when this happens the brake is engaged some as well holding back the tractor a bit. Then there are times the pedal feels normal and right brake works fine. Anyone have thoughts as to what could be causing the issue? Rear hydraulic fluid is at normal level as well. I did notice some oil residue though around the right hub.
Thank you.
Thank you.
