2010 new holland workmaster 55 hydraulic control valve
   / 2010 new holland workmaster 55 hydraulic control valve #1
Msks
Workmaster 55
Does anyone know of an aftermarket replacement for a control valve for a font end loader on workmaster 55
   / 2010 new holland workmaster 55 hydraulic control valve #2
You need to know the flow capacity of the existing control valve and you can try Surplus Center, or a hydraulic supply house to get a replacement. Most likely it is an open center valve. Is a NH part too expensive? It will probably be a direct fit.
   / 2010 new holland workmaster 55 hydraulic control valve #3
Summit hydraulics or Bailey hydraulics have several reasonably priced joy stick assemblies.
The main differences would be in the body threads and adapters required.
   / 2010 new holland workmaster 55 hydraulic control valve #4
What is wrong with the valve currently on your tractor?
Valve is bypassing bucket drops about 6" per minute I raised the bucket unplugged from the control valve it didn't drop at all overnight .I've never been fond of the joystick on this tractor and was hoping to upgrade
   / 2010 new holland workmaster 55 hydraulic control valve #6
Did you unplug both hoses or just the cap end? Reason for asking is that the cylinder seals could be leaking along with valve. More than one person has found that replacing the cylinder seals solved the drift issue.
Are you unhappy with fine movement -feathering capabilities of existing valve?
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2012 FORD 4 DOOR TAURUS SEDAN (A54607)
2012 FORD 4 DOOR...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
