2011 Kubota L3200 HST Filters Help
   / 2011 Kubota L3200 HST Filters Help #1
loudhornsrule
I have found all the filters(wix brand) except the trans. filter and the Hydrostat filter. Does anyone have a non kubota part number such as wix, napa, or purolator for this application. I dont get caught up in all the genuine high dollar kubota parts gimmicks. I am sure kubota does not make filters. Any help would be appreciated. Thanks
Just got raped by Kubota. Couldn't wait any longer so went down to local Kubota for the filters. $77 bucks for those 2 filters, and they didn't even use any vaseline. That is rape. As soon as I find out the wix or napa numbers I will post them.
   / 2011 Kubota L3200 HST Filters Help #3
I recommend sticking with Kubota filter while you are under warranty so if you have a issue they can't say you weren't using our filter. If you give me the kubota part number I can try crossing it over at Napa. I tried looking it up by application but they did not even list it by application. How much were the filters?
   / 2011 Kubota L3200 HST Filters Help #4
Good luck finding them.. I think one can be found , but seems to me the other one I think the hydro filter cannot be found. All of these type of filters on all brands are very expensive.. I think I gave $80 for the hydro filter alone on my Kioti. If you do find good replacements be sure to post up the links where they can be found, I am sure a lot of the guys would appreciate it.
James K0UA
   / 2011 Kubota L3200 HST Filters Help #5
Great thread here. I use Kubota filters because I perceive them to be a greater value but the OP is right and I'm sure Kubota makes nothing and subs it out. I'd also bet there is a lot of cross-over as well and in fact my JD 790 has the same air filters as my Kubota L4300.
Years back I used to have the big Wix and Fram Industrial filter cross reference books and most everything from back then crossed over to one or the other. Wix makes a great filter and it will be interesting to see any price differential. As I recall, I stayed with dealer filters because there wasn't much of a price difference when there was an alternative competitor, The only time Kubota seemed outrageous was when they were the only filter out there and there was no cross-over to go to.
   / 2011 Kubota L3200 HST Filters Help #6
The filters for the Bobcat were reasonable. The oil filter was the only one wix had and it was the about the same price as a Bobcat. I saw a exploded view of a Bobcat filter and it looked like a wix.
HH3A0-82623 $47.26 HHK70-14070 23.75 Plus Tax =76.87 That hurt the old pocketbook!
   / 2011 Kubota L3200 HST Filters Help #8
I tried them at NAPA and Carquest with no luck:mad: I then went to wix and I found all the filters like you had by application. I tried the Kubota number HHK70-14070 on their interchange and found a filter. I could not find one for the HH3A0-82623. Check and be sure these filters will work before you use them. Added the rest of the filters for a reference for anyone else.
Kubota # Wix# Napa#
HHK70-14070, 51367, 1367 (should be around $15)
air, 42985, 2985
air, 46438, 6438
fuel, 33830, 3830
engine, 51307, 1307
Sorry my chart did not turn out good after I hit submit.
Wix Filters - Product Catalog search results
If you can find the filters in any brand post the number and I will try to cross it at napa or carquest. They both sell Wix filters. I tried finding the last filter in a Wix, purolator, fram, hastings, and donaldson. You can do a filter request at wix. http://www.wixfilters.com/Lookup/PartResearch.aspx
Roger, thanks. The filter HH3A0=82623 FOR $47 BUCKS has a removable magnet in the top.
   / 2011 Kubota L3200 HST Filters Help #10
You're welcome. I looked everywhere I could think of for that filter, I also checked mile guard. I think you may have to do a filter request and see what wix can do.
2014 Dodge Grand Caravan Van (A59231)
2014 Dodge Grand...
JOHN DEERE 7210 TRACTOR (A60430)
JOHN DEERE 7210...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
2414 (A60432)
2414 (A60432)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere S350 (A60462)
John Deere S350...
