Buying Advice 2013 Kubota BX2370?
   / 2013 Kubota BX2370?
Thanks TripleR I wasn't aware it was quite that easy on the loader!
   / 2013 Kubota BX2370? #23
Keep in mind, to "avoid disappointment" Always take your loader off on solid level ground. If it sinks on one side, it can be a "bear" to get back on.
   / 2013 Kubota BX2370? #24
I can't imagine a newer tractor without a loader.
All of the on/off with loader would be done in barn on concrete floor. Shouldn't be a big deal but thanks for the heads up.
   / 2013 Kubota BX2370? #26
The first time or two "may" be a little sticky due to paint, but we just stepped on the front bucket edge and ours popped right up. We routinely install/remove FELs on our BX and GL.
   / 2013 Kubota BX2370? #27
Absolutely the best place. I have seen the results of trying to hook back up with one side sunken in the mud.. Not pretty. Probably be OK with a small loader like a BX, because you can "muscle" it around, Not so easy when it weighs a bunch more.
   / 2013 Kubota BX2370? #28
Yeah, I was going to use a jack on mine to line it up after it sank in, but my son just walked over and picked it up.:eek::laughing:
Does 14400 OTD sound like a reasonable price for the BX2370 with FEL? 0% x 72
   / 2013 Kubota BX2370? #30
Doesn't seem out of line to me. Not sure how the price varies by region and where you are located. You can go to the Kubota website and 'build your own'. It will show pricing for base and any options you want. Use this for reference and try to better it by 5 or 10%. Sometimes with financing they don't give you much room to maneuver though.
Ford F-450 Utility Truck (A52748)
Ford F-450 Utility...
Wanco 800W Solar Integrator Trailer (A51691)
Wanco 800W Solar...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
2016 TRAILSTAR 40FT DUMP TRAILER (A52576)
2016 TRAILSTAR...
