taylor.coulon
- Joined
- Sep 18, 2021
- Messages
- 1
- Tractor
- 2013 Mahindra 3016 Shuttle
Hi guys I'm in need of some help with my tractor. I'm having to pull my fuel line off at the fuel bowl, push air towards the tank and once the air comes out the fuel bowl I'm good to go. I reinstall the line and the tractor will run perfect for about ten minutes, under load or not. So far I have drained the tank and used a shop vac to remove any debris/dirt. Used a straight pick to going into the barbed fitted for the fuel line into the tank to verify no blockage. Replaced all fuel lines from the tank to the electric pump. New fuel filter, there is not fuel shut off valve to be clogged. Air filter is brand new. I removed pump and tested with a tank and bucket it pumps perfectly fine. I can drain the fuel bowl, reinstall and turn key its fills in just seconds. The fuel cap gasket is crapped out, but I have tried running it with no fuel cap and it still does it. Maybe the return line for the high pressure fuel pump to the tank is clogged? I'm pretty good with diesels but this one has me stumped. Any help is much appreciated, Thank you
